Activity Forums Blackmagic Design Mac-drive is slowwww
  • Mac-drive is slowwww
    Posted by Bo Skelmose on June 8, 2012 at 12:33 pm
    Hi
    Installed the Mac-drive software on one of my machines – now it has gone very low in speed – taking 14-24 hours to copy a 128gB SSD disk via e-sata or usb2. I cannot install it on another machine because I only have license to the “slow” machine. Any idears how to change the license to another machine – I’m stocked with this software to use Black Magic Hyper deck Shuttle…..
    Found out that the software could be deactivated and activated on another machine – hope it works on my old HP
    Dave Gosley replied 13 years, 7 months ago 6 Members · 7 Replies
  • 7 Replies
  • Tom Bassford
    June 8, 2012 at 1:05 pm
    I would recommend you look at Transmac software as a replacement for MacDrive. It’s much better in my experience.
    https://www.asy.com/scrtm.htm
    https://ATEMuser.com
  • Richard Crowley
    June 10, 2012 at 7:30 am
    Yes you are supposed to be able to transfer the license. You can also buy a 2-computer license for not much more than single license.
    I had exactly the same problem with my AJA KiPro drives until I tried connecting them directly via SATA (a method NOT endorsed by AJA). Now I get quite reasonable transfer times out of them.
  • Jay Bloomfield
    June 10, 2012 at 4:43 pm
    There is a big difference between the two. MacDrive is invisible to the user for most file operations. Transmac is separate program that you have to run every time you want to access a Mac-formatted drive. Its interface looks a lot like the Windows Explorer. Both are somewhat slower at copying files than a “normal” Windows file copy. That’s just the nature of the extra software layer that’s needed to read and write Mac-formatted drives under Windows.
    Other than that, they both seem to do the job for most people.
  • Bo Skelmose
    June 10, 2012 at 9:40 pm
    Seems to be a computer problem esata/usb2 transfer 4-5 mb/s – works fine on usb2 on my old HP. I’ll look into it.
  • Ninetto Makavejev
    June 12, 2012 at 2:50 pm
    I remember reading somewhere that certain controllers (Marvell?) have quirks with SSD-disks connected externally. Esata should of course be much faster than USB 2.0 Or do you see this effect ONLY with Mac-Formated SSDs? Maybe they were not properly aligned when formating in Apple? Or did you format the disks via MacDrive? There was a acknowlegded MacDrive 9.0 bug whilst formatting but that has been fixed, and I believe it was for mixed formats NFTS/GPT…
    In any case it would be good to hear if you found a solution to this. Everyone on the block is lusting after SSD-Disks these days…!
  • Dave Gosley
    February 14, 2013 at 12:59 pm
    Have same problem with MacDrive. Trying to take files off a drobo that was mac formatted.
    MacDrive sees the drive just fine. But transfer off it is a labour intensive 10MBps.
    PC is a new one with win 7 pro. The drive I am transferring to is a seagate 7200 3TB internally installed on SATA – and was bought new in Feb 2013.
    I have changed the firewire driver to the legacy version – got a minimal increase from 7 – 8 MBps to the 10.
    Then changed to the ubicore driver – and no difference.
    I tried transmac – and once installed it could recognise the drobo as a disk – but could not connect to it – stating “disk access error” so never got it to work.
    I am waiting for the folk at mediafour support to respond again – having responded once to recognise my request, the immediate was to ask if I had tried and alternative connection.
    Yes – tried firewire and usb – same result.
  • Dave Gosley
    February 17, 2013 at 1:17 am
    Having emptied the mass storage device on the Firewire – I continued using MacDrive to empty some other archive folders off separate drives – this time using an external esata docking station.
    The drive I am taking stuff off is a 7200 / 6GBp/s and its feeding a PC formatted 7200 / 6GB/ps drive – via a sata cable.
    MacDrive is maintaining a rate of 116MB p/s – which is way better.
    I am persuaded the problem was not with MacDrive but with Firewire – even with the ubicore driver.
