Activity Forums Adobe Audition Mac crashes with Adobe Audition 2020 is running.
  • Mac crashes with Adobe Audition 2020 is running.
    Posted by Tom Maul on July 30, 2020 at 3:54 am
    Mac crashes with Adobe Audition 2020 is running (OS Mojave 10.14.6).
    I am attempting to input an audio feed from another Mac via a Fast Track (M-Audio) Mini Mixer, or the iMac USB Audio System (Micro Mini Unit).
    The recording for both Fast Track and iMac USB starts and runs for about 4 or 5 minutes and crashes.
    Any suggestions?
    Advance thanks
    TM
    Jennifer Schroeter replied 4 years, 8 months ago 2 Members · 2 Replies
  • Jennifer Schroeter
    December 31, 2021 at 8:36 pm
    If your computer is crash while you are running Adobe Audition, then you should check your computer memory first. If your computer memory is low, then you may get crashes. In this case, you should check the free hard disk space and install the latest version of Adobe Audition, because it is not compatible with the previous version.
