Activity Forums VEGAS Pro Mac Cinema Display on PC?
  • Mac Cinema Display on PC?
    Posted by Lee Mceachern on June 29, 2006 at 6:59 pm
    I have been doing more and more editing on Vegas and less on my Mac-based Media 100. But I really miss using my 22″ Mac Cinema Display. I’m checking around, looking for cards that I can put in my PC to drive the Cinema Display so that I can use it for Vegas diting. Has anyone here done that successfully? (BTW, I think the 22″ Cinema Display is different in this regard from the larger ones, so this might have to be a 22″-specific solution.)
    TIA for any help.
    Lee
    Rob Mack replied 20 years, 2 months ago 4 Members · 4 Replies
  • Terje A. bergesen
    June 29, 2006 at 8:25 pm
    Any modern graphics card for the PC has a DVI output. You should be able to use just about any recent graphics card. If your PC is relatively recent I bet it’s graphics card already has DVI.
  • Valvehead
    June 30, 2006 at 2:34 am
    According to Apple, only the 30″ model requires a dual-link DVI connection. For the smaller cinema displays a normal DVI connection will be sufficient. Just make sure that the video card supports the required resolution over DVI (the analog resolution capabilities may be much higher than DVI).
  • Lee Mceachern
    July 1, 2006 at 12:31 am
    Thanks for taking the time to answer. I will probably buy a new card anyway because I’d like to operate with two monitors and I don’t think th existing card is dual channel. But the answers here have helped me. Thanks!
    Lee
  • Rob Mack
    July 2, 2006 at 2:28 am
    I’m using what I think is a 22″ cinema display on a PC. It’s the plastic one with a kickstand, right?
    It was originally on a Media100 as well. it requires a boxfor power, USB , and all that but maybe that was stock from apple.
    Love the display but wish I could put it on an arm.
    Rob Mack
