Activity › Forums › Adobe After Effects › mac book pro and after effects
Posted by Mark Joseph on March 18, 2008 at 2:12 amok need help, I just bought a macbook pro , I usually work on a macpro, I am trying to render preview in ae cs3 the short cut on my mac pro is the 0 zero key on my number pad , it is not working on the macbook pro ny thoughts,,,
Steve Tarlton replied 18 years, 6 months ago 4 Members · 5 Replies -
Brian Berneker
March 18, 2008 at 3:26 amI’d say get one of the new brushed metal keyboards (my favorite) and just run external. You could go out of your way setting up new hot keys or learning to use the menus, but that will just take away from the usability of After Effects.
You can also just buy an external num pad as well, which is smaller. There is an article on how to make sure it works here:
https://www.macosxhints.com/article.php?story=20080310030635237
Personally I’d just use the notebook for photoshop and other out and about activities, but save my AE work for times when I can sit in front of a big screen.. my 46″ 1920×1080 Toshiba.. Effects just seem more meaningful on a big screen to me, and enhance creativity.
You could set up a workstation to plug in to a full keyboard and monitor… I guess I’m getting way off topic by now…
Brian
Steve Tarlton
March 18, 2008 at 4:18 amAre you using “fn” and the letter “m” which is the “number pad” equivalent to 0 on the mbp? I think that should work.
Steve
Brian Berneker
March 18, 2008 at 6:45 amYes, of course most notebooks have a key for toggling some keys on the keyboard back and forth into the numeric keypad, but then you get into overlap on those keys that have other functions when they’re not as numbers… like I said before.. it gets unwieldly..
Of course, it does answer the original question… how to do it…
Steve Skazenski
March 18, 2008 at 3:26 pmThe newest MacBook Pros (and MacBooks and the new wireless keyboard) no longer have the fn numpad.
You can modify the keyboard shortcuts file found here:
~/Library/Preferences/Adobe/After Effects/8.0/Adobe After Effects 8.0 ShortcutsSearch for “Preview” (with quotes).
(Pad0) is the number pad zero key, try changing that to something else, maybe an F key?
Steve Tarlton
March 18, 2008 at 3:27 pmAgreed. It is definitely not preferrable. I use one of the older wireless keyboards at work, but I don’t haul it back and forth to my house, so I end up doing a lot of late night editing with the MBP keyboard. It is a pain.
Steve
