Activity › Forums › Apple Final Cut Pro Legacy › Mac and FCP don’t see DVD in drive – import problems
  • Mac and FCP don’t see DVD in drive – import problems
    Posted by Jon Davidson on October 10, 2005 at 6:14 am
    I’m trying to import footage into Final Cut Pro from VHS tape and an unprotected computer-burned DVD. My program won’t import the DVD video files properly (only a few seconds of the VOB files), and when I converted the VHS tape to DVD via my Sony VCR recorder, my apple computer pretends it’s a blank disc and won’t even recognize that’s it’s in the DVD drive. I don’t have a specialized deck for importing VHS tapes, so converting to DVD I thought would be an option. Can someone tell me what’s going on? I’ve been pulling what’s left of my hair out for days now. Thanks.
    David Rowan replied 20 years, 11 months ago 5 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    October 10, 2005 at 6:29 am
    What are you trying to use to extract the DVD files? DVDxDV? MPEGstreamclip? Mac the Ripper?
    And what type of DVDs are you burning the VHS tapes onto? DVD+R? Macs cannot read +Rs.
    Any issue with looping the VCR thru your camera? Or dubbing the VHS to DV, then capturing?
  • Walter Biscardi
    October 10, 2005 at 10:47 am
    [Shane Ross] “DVD+R? Macs cannot read +Rs.”
    A mac can read a burned DVD+R just fine. I burn +R’s in my Philips DVD Recorder and can play back the discs in all my Mac’s just fine.
    The newer Mac’s, like my Mini, can now burn both -/+ R’s.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
    G5 Dual 2.0, AJA Kona 2, Medea FCR2X
  • Shane Ross
    October 10, 2005 at 11:27 am
    Oop. What the HELL was I thinking?
    Big DUH here. Apologies.
  • Walter Biscardi
    October 10, 2005 at 11:46 am
    [Shane Ross] “Oop. What the HELL was I thinking? Big DUH here. Apologies.”
    Never a need to apologize here, Heck I don’t get everything right. That’s why there’s so many of us here to help back each other up. 🙂
  • Michael Alberts
    October 10, 2005 at 1:32 pm
    Many of the earlier Superdrives were not able to read DVD+R disks. If you have a G4 with a Superdrive that might be the case. As for the VOB file try using DVDxDV. For the VHS tape, the inexpensive way to get that into your system would be to purchase a A/D coverter like the Canopus ADVC 100. This box is useful if you’re want to convert the analog to DV. If you’re working at a higher, uncompressed rate than any of the third party video cards should work for you (Aurora, AJA, Decklink).
    Michael Alberts
    Ambidextrous Productions, Inc.
  • David Rowan
    October 11, 2005 at 5:31 pm
    DVD’s are really not a great source for video. As the other posts indicate you really need a 3rd party conversion tool(program) to “dis-assemble” the DVD and “re-assemble” it into a quicktime file you can use.
    If you have a capture card or a firewire device (camera or deck) with an input it would be better to run the signal from your VHS deck through that, and capture via firewire. Same goes for the DVD, just hook up a DVD player and play it through your firewire camera or capture device.
    I’m fortunate enough to have an AJA IO, so I quit dealing with trying to convert DVD’s. Its just a lot simpler to play them from a DVD player. The way they were meant to be used. I don’t imagine that a good DVD player sending out a signal over S-VHS or Component would have worse image quality than taking the MPEG file of the disk and running it through some 3rd party program.
    DWR
  • David Rowan
    DWR
