Activity › Forums › Apple Motion › M5 Keyframe Copy/Paste Bug and Workaround
  • M5 Keyframe Copy/Paste Bug and Workaround
    Posted by Don Smith on July 30, 2011 at 11:01 am
    It drove me crazy not to be able to copy keyframes in the keyframe editor and past them elsewhere on the keyframe timeline. I reviewed the Help instructions and they were no different from Motion 4.
    I’m a keyboard guy and that was my downfall as it turns out. I was pressing CMD-C and CMD-V to copy and paste keyframes. To catch up those who don’t yet know, you can go into the keyframe editor, put the playhead where you want to PASTE keyframes then using the arrow tool (edit selection tool I think. I’m not in front of M5 right now), lasso or select the keyframes you want to copy. Once they are highlighted, it’s simply CMD-C, CMD-V. The highlighted keyframes are copied and magically appear where the playhead is. At least that was how it was in Motion 4.
    But it wouldn’t work in Motion 5.
    That is, until I broke my convention and instead of pressing CMD-C I went to the Edit Menu > Copy. THEN pressing CMD-V worked! So, in Motion 5, CMD-C is non-functional (in the Keyframe editor anyway.. I don’t know about elsewhere) even though the menu item for Copy is CMD-C.
    I traced this problem by checking checking with the Edit menu to see if ‘Copy’ was still greyed out when I tried ways to Copy the keyframes I wanted to paste elsewhere. Only when I did the Copy through the Edit menu did the ‘Copy’ became full opacity and not greyed out.
    Don Smith
    NewsVideo.com
    Mark Spencer replied 15 years, 2 months ago 2 Members · 3 Replies
  • Mark Spencer
    July 30, 2011 at 11:12 am
    Don I think it may be an issue with your system or install because copy-paste with the shortcut keys works fine on my machine.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Don Smith
    July 30, 2011 at 11:19 am
    Well, rats. Thought I was contributing something. But that revelation makes me wonder if the other problems I’ve been asking about are isolated to my installation. Thanks Mark. Sorry you’re up so early there in Cali-forni-i-a.
    Don
    NewsVideo.com
  • Mark Spencer
    July 30, 2011 at 11:20 am
    I’m actually currently in Delaware where it’s a reasonable hour 🙂
    Mark Spencer
