Activity › Forums › Apple Final Cut Pro Legacy › ‘m2v1’ conversion???????
Posted by Korey Kacz on October 18, 2008 at 7:52 pmHere is my dilemma- I have several video files that are .MOV files but I noticed under codecs is ‘m2v1’, Integer ( Little Endian), Timecode
-I have no idea what camera they came from. I only get audio when Quicktime 7 + Quicktime mpeg2 Playback opens the files. The same with Streamclip. I need to covert them for a FCP project. Has anyone else come across this problem?Rafael Amador replied 16 years, 10 months ago 5 Members · 7 Replies -
Jaap Verdenius
October 19, 2008 at 8:50 amThere are a few threads on this issue at http://www.mindsuburbia.net/2008/08/28/70/ and on discussions.apple.com/message.jspa?messageID=8280037. The guy who had the same problem as you was working on OS 10.1 or something. Which version OS, FCP and QT are you using?
Jaap
Korey Kacz
October 19, 2008 at 4:03 pmI am totally updated in OSX and Quicktime. I tried Streamclip, Perian,Mpeg2-Playback QT, VLC and DiVX. I have read all the google links that I could so CC was my last resort. I am at a loss a this point.
David Roth weiss
October 19, 2008 at 5:25 pmSteamclip does work for this, so I would have to imagine that some degree of pilot error is involved that is causing you to thnk it doesn’t work.
Trying an app and using it properly are often two separate things. So, why don’t you try to give us the exact details of your methodology and settings using Streamclip and perhaps we can guide you properly along your way.
Meanwhile, since we’re forced to guess, my guess would be that you’re choosing Streamclip’s option to output to DV instead of Quicktime DV.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
Jaap Verdenius
October 19, 2008 at 6:22 pmThe guy in the mindsuburbia forum mentioned editing the .mov with a hex editor (like 0xed).
He searched for m2v1, found the string twice, replaced it with mp2v, saved and then it worked – that’s what he wrote.Did you try that?
Jaap
Korey Kacz
October 19, 2008 at 10:17 pmjaap- you were right on OxED. I changed a couple of letters to mp2v and the clips played fine.Thanks
Matt Lambert
October 12, 2009 at 4:28 pmI used 0xed, searched for m2v1 and replaced both occurrences with mp2v and saved, and my mac still can’t read the video for these files. what am i missing here?
