Activity Forums Adobe Premiere Pro m2v re-export PLEASE HELP!
  • m2v re-export PLEASE HELP!
    Posted by Marc Thomas on July 11, 2009 at 5:53 pm
    Hi, my problem is that I made an AVI movie file a while back that was 73 minutes long and 10 GB large. My external hard drive died, so I’m left with the m2v transcoded version of the film that is 4 GB large.
    The quality looked ok… but now I’ve been asked to put the bonus features onto the same disc (there’s no other way around it), which means that I had to re-import the m2v into PP and re-export it again (but a little smaller to allow room for the bonus features). I was told that keeping it mpeg2 wouldn’t degrade the quality… so I tried “mgeg2” instead of “mgeg2-DVD” (m2v) so that the audio and video would be one file (because I don’t know if there’s a way to link up already-separated audio/video in ENCORE?). The new file was 3 GB, and looked good in some parts, and completely unacceptable in other parts. Very frustrating!
    My question is. What is the best format, and settings to export a 4 GB (m2v) movie to about a 3 GB movie without losing (too much) quality?
    I’m open to ANY ideas.
    Thanks for your help, as it would be very welcomed and appreciated!
    Marc
    Mike Velte replied 17 years, 1 month ago 3 Members · 6 Replies
  • Eric Monroe
    July 11, 2009 at 8:53 pm
    Marc, I am not sure as to why you would be having quality issues in part of the video and not other parts.
    I can however tell you that in adobe encore you can import the .m2v (mpeg2-dvd) into encore and have it treat it as one linked file. I do all of my edits this way….because mpeg2-dvd will carry the chapter markers from premiere’s timeline over into encore.
    right click in encore’s project panel
    import as “timeline”
    select both the audio and video files in the import window at the same time.
    click open in the bottom right of the import window (or “ok” cant remember off the top of my head)
    encore will import everything into the proj. panel
    (you will see a total of 3 icons in the proj panel for what you just imported. the video, the audio, and encore makes one for the timeline, double clicking the timeline icon will open that video’s audio and video in the timeline at the bottom automatically)
    (also upon importing you should see the video thumbnail in the bottom of the flow chart window waiting for you to connect it to the appropriate part of your menu.)
    i hope that helps you out, at least a little. As far as the quality issue, I am anxious to see if anyone else has the answer to that one. I have been using mpeg2-dvd for everything that i do for a few years now, and quality has never been an issue. maybe i have been lucky :o)
    Eric Monroe
    Shadow Studios
  • Marc Thomas
    July 11, 2009 at 9:28 pm
    Hi Eric, thanks for the reply.
    The quality looks fine in daytime parts of the movie, but some nighttime stuff, and some moving titles at the beginning look terrible. The titles look very jittery and some night shots of tree tops look really blurry.
    I’m assuming it has something to do with the bitrates?
    **So I’m trying to find the best quality settings for making the 4 GB m2v into a 3 GB m2v (approx.).
    As for importing the audio and video into ENCORE… worked like a charm! Thank you for that tip!! 🙂
    Marc
  • Mike Velte
    July 12, 2009 at 10:42 am
    Video quality degrades with compression. This degradation is acceptable when going from 25 mbps (HDV or DV) to 8 mbps (mpeg2 DVD). Your workflow then recompresses the video again, but the source and output are basically the same low bitrate and the degradation is going to be much worse.
  • Marc Thomas
    July 12, 2009 at 8:09 pm
    Thank you Mike for that info. Makes sense.
    I was given some info that it wouldn’t recompress because it was being exported as the same format… but I guess that doesn’t really make sense after all.
    It’s just a shame that I lost so much data with my hard drive that got fried… and I don’t have the money for data-recovery.
    I wish there was another solution, but I guess there’s not… especially since I’m also restricted by file size.
    Thanks again for the reply everyone.
    Marc
  • Marc Thomas
    July 12, 2009 at 8:13 pm
    Out of curiousity, I was reading another thread that mentioned:
    1) Videoredo.com
    2) Edius Procoder
    As software that could export without recompression… assuming they work… I guess they wouldn’t help me since I need a smaller file than the original video?
    Just thinking out loud, but if anyone knows anything about these please let me know.
    Thanks again!
    Marc
  • Mike Velte
    July 13, 2009 at 10:39 am
    VideoRedo Plus allows for cuts only edits and then stitches the remaining clips together without recompression.
