Activity › Forums › Adobe Encore DVD › m2v & m4v on same blu-ray
  • m2v & m4v on same blu-ray
    Posted by Hagop Goudsouzian on February 26, 2013 at 4:16 am
    will I have issues down the road if my blu-ray contains mostly m4v and for 3 shorts (3x2min) m2v? So far as blu-ray players compatibility and replication issues and other problems?
    Both compressor (h.264) and ame (m4v) regardless of bit rate are giving me problems, yet when I encode m2v, it seems to be fine, only on these three shorts.
    Hagop
    Hagop Goudsouzian replied 13 years, 7 months ago 2 Members · 4 Replies
  • Bill Stephan
    February 26, 2013 at 6:40 pm
    Unless you are encoding using a high-end spec-compliant hardware encoder such as the Sony or Sonic Blu-ray encoders, forget about using MPEG-2 for Blu-ray. The h.264 for Blu-ray preset in Apple Compressor 3 or 4 is Blu-ray spec-compliant, and you will be able to replicate using these encodes.
    Note that Encore will NOT produce a usable BDCMF for replication unless you run your project through Blu Streak Premaster.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Hagop Goudsouzian
    February 27, 2013 at 2:07 am
    Great! Thank you Bill.
    BTW, how much space should I allow for the BDCMF process in case I do need to go to replication, without re-authoring?
    I can not do BDCMF myself, I will have to find someone to do it for me (eventually).
    Right now I have about 800mb of free space on a single layer BD-R.
    Hagop
  • Bill Stephan
    February 27, 2013 at 5:21 pm
    Our company does not do the premastering process for replicating from Encore, so I cannot give you an authoritative answer. But the size of the assets should not increase because of Blu Streak Premaster.
    Bill Stephan
    USA Studios
    New York City
  • Hagop Goudsouzian
    February 27, 2013 at 7:24 pm
    Thank you.
