Activity › Forums › Compression Techniques › m2v incompatible format in DVDSP
  • m2v incompatible format in DVDSP
    Posted by Abi Shapiro on September 28, 2009 at 5:22 pm
    Hi! In desperate need of some advice:
    I have been exporting a sequence from FCP to Compressor where i’ve used mpeg 2 Elementary stream and a seperate audio compression AIFF 48:16.
    Audio is all good, but DVDSP will not accept the m2v file, saying ‘Incompatible Format’
    If these are my sequence settings :
    Frame size: CCIR 601/DVPAL (5:4)
    pixel aspect ratio 720:576 PAL CCIR 601
    Editing timebase: 25
    and here’s the elementary stream mpeg2:
    Description: MPEG-2 Elementary Stream, 15 Mbps.
    File Extension: m2v
    Estimated file size: 6.59 GB/hour of source
    Type: MPEG-2 video elementary stream
    Usage:generic
    Video Encoder
    Format: M2V
    Width and Height: Automatic
    Pixel aspect ratio: Default
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls: Automatically selected: Off
    Start timecode from source
    Aspect ratio: Automatic
    Selected 16:9
    Field dominance: Automatic
    Average data rate: 15 (Mbps)
    2 Pass VBR enabled
    Maximum data rate: 20 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 1/2 second, Structure: IBBP
    what does the (5:4) on the sequence’s frame size mean?
    I am still quiet new to all this so forgive my ignorance,its about 11minutes long w 2 audio outputs…
    Any help would be amazing, thank you
    Abi Shapiro replied 16 years, 12 months ago 3 Members · 4 Replies
  • Craig Seeman
    September 28, 2009 at 6:29 pm
    [Abi Shapiro] “Average data rate: 15 (Mbps)
    If you don’t know what you’re doing please start with a preset. Apparently you don’t know what data rate DVD Video can handle. You can not “turn up the volume up to 11” you must stay within DVD spec.
  • Andrew Saliga
    September 29, 2009 at 3:05 pm
    Like Craig said, your data rate is too high. DVDs can handle a max of 9.80 Mbit/s total for the audio and video content on the disc. I’ve had issues with DVDSP not accepting .m2vs that were even within this spec.
    You obviously want to be able to have the highest quality video possible, but you also don’t want to deal with cheaper players not being able to play a disc. I’m not sure how much of an issue this is anymore, but I’ve heard of people having problems.
    So, short answer use a preset, aka lower the data rate.
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com
  • Craig Seeman
    September 29, 2009 at 3:19 pm
    Some will keep peaks to 7.7mbps, others 7.2mbps. I’ve had peaks as low as 6.5mbps (and CBR will work for shorter encodes) because I’ve seen some very finicky older players.
  • Abi Shapiro
    October 1, 2009 at 11:07 am
    Thank you Andrew,
    I obviously got all the data advice a bit mixed up and didn’t even look twice at the elementary stream preset! Running short of time I took your advice and opted for the easy option and less quality, and it all worked out well. Relief!
    youre a star
