Activity Forums Adobe Premiere Pro M2V Encoding problem
  • M2V Encoding problem
    Posted by Joe Bandy on January 13, 2009 at 5:47 am
    I’ve been trying to make an M2V to burn to bluray using CS3. I have tried a couple different times and every time the compression get to about 99.9% it stalls out and doesn’t complete. It stops responding and I have to end the program using task manager
    After a couple of try’s the compression always stops between 6-10 frames from the end of my workbar area. When I watched the file it seemed to fade to black at the end and then go backwards a little bit where I could still see some video.
    Has anyone else encountered this problem?
    Joe Bandy replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
