Activity › Forums › VEGAS Pro › m2ts video file skips on Vegas 9.0b
  • m2ts video file skips on Vegas 9.0b
    Posted by Joe Ryan on June 27, 2009 at 8:53 pm
    I transfered video from a Canon HF-100 videocamera, and drop the files into Sony Vegas 9.0b.
    It shows up ok..but when I play it the video skips a lot, as if it plays every other second. not a normal viewing experience. the only thing that seems to work right is the audio- that sounds normal.
    As an example, I rendered an MPG and uploaded it to my site:
    https://www.gratefuljoe.com/gallery/7780151_pcfBV#573135785_YwKUU-A-LB
    In this MPG version, now the both the video and audio jolt & skip.
    Anyone have ideas what could be the problem? Is it the fact it’s a Canon video file with a Sony program???
    -at a loss,
    Joe
    John Rofrano replied 17 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    June 28, 2009 at 3:10 pm
    I have never seen stuttering on rendering unless there was a codec conflict so it sure points to the Canon files. I know that Sony cameras use a different AVCHD profile than Canon and, in fact, when I bought my AVCHD camera, I purchased the Sony HDR-CX12 specifically because I knew that it’s files worked well in Vegas. I thought Sony had fixed some of the problems with Canon files in Vegas Pro 9.0. I assume you are using Movie Studio 9.0b which is older and may not have these fixes.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
