Activity Forums Apple Final Cut Pro Legacy m2Ts Files on MAC
  • m2Ts Files on MAC
    Posted by Arturo Celleri on August 4, 2008 at 11:56 pm
    I’m not sure this is the place to ask this question, but if you know something regarding this issue or could recommend me to another resource I’d appreciate it.
    I have a external hard drive (Western Digital 1TB My Book) with m2Ts Video Files on it. I used a pc with Windows to download the files on to the drive.
    Now I have a MAC Pro and when I plug in the drive , it doesn’t show me the files (only folders). When I plug it back into the pc…I can see the files but not open them.
    I need to know how to open and use them on both a MAC and a PC.
    Any ideas?
    Arturo Celleri
    Arturo Celleri
    Paulo Debenest replied 16 years, 2 months ago 12 Members · 20 Replies
  • 20 Replies
  • Sean Oneil
    August 5, 2008 at 7:20 am
    The VLC player for Mac should play them. But if you can’t see them then that’s not going to help you much. I have no idea why you wouldn’t be able to see them.
    Sean
  • Angela Anderson
    August 5, 2008 at 11:31 am
    what os do you have? leopard should be able to read the files.
  • Carlo Ferraro
    September 15, 2008 at 10:49 pm
    I got m2t files on Focus FS-4HD drives recorded from Canon XLH1. I try to load on FCP (I am a novice on MAC) and although the files are shown they can neither play back not loaded on the project.
  • David Roth weiss
    September 15, 2008 at 11:14 pm
    You have to use MPEG Streamclip (freeware) to convert the files to a Quicktime format that can be edited in FCP.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Carlo Ferraro
    September 16, 2008 at 12:20 am
    David:
    Thanks.
    I was on it prior to your response, searching for other issues. What is in your opinion the best conversion:
    1-Apple FCP uncompressed video
    2-Apple Pro Res 422
    I plan, as I did in Vegas to clean and keep the footage in uncompressed files to avoid artifacts.
    Carlo
  • David Roth weiss
    September 16, 2008 at 12:29 am
    Unless you have a massive very fast raid, ProRes will do just fine.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Daniel Froidevaux
    November 23, 2008 at 2:49 am
    HELP, please.
    I just tried to use MPEG Streamclip 1.9.2 to export m2Ts files to quicktime files so that I could edit in FCP. First when i went to select the m2Ts files they were not accessible as video files. I changed the file setting to “all files” and then batch selected an entire folder of the m2Ts files. when i went to export (i dont understand why it does not call for a conversion) to .mov files an error message popped up for each m2Ts file: “the first video frame was not found” Evidently the program is not recongizing these files as video files. How can i convert these m2Ts files so I can edit in FCP.
    quod me nutruit me destruit
  • Elijah Lynn
    December 6, 2008 at 6:05 am
    Relevant info.
    https://www.clipwrap.com/overview.php
    Clipwrap wraps *.m2ts files into .mov files. I have not tried this yet.
  • Elijah Lynn
    December 8, 2008 at 6:13 pm
    I just tried the Clipwrap demo on the *.m2ts files for a Canon HF10 and it does not work.
  • Daniel Froidevaux
    December 8, 2008 at 10:53 pm
    There has to be an easy and accessible way to deal with these files. My friend shot the video on a new consumer-level Sony camcorder, and I have 1500 dollars worth of professional video editing software on my computer. All I want to do is cut this video. Is FCP developing a patch to deal with AVCHD footage? Are the m2Ts files an intermediate codec that only run on PC’s? Should I try directly importing from the camera? Do I need Sony software to deal with this amazing high-end and utterly useless new compression?
    I have searched high and low to find an answer to these questions and have found nothing of substance. Given the lack of success I am enjoying with suggestions posted on boards such as these, there is no way I am going to risk buying conversion software from an unknown provider.
    Does anyone know how to deal with AVCHD/m2Ts files on Macs running FCP?
