Activity Forums Media 100 M100i crashing on transitions HELP!*
  • M100i crashing on transitions HELP!*
    Posted by Ted Joyce on April 24, 2007 at 9:25 pm
    Recently I’ve had M100 application crashes when trying to open transitions on multiple programs & projects and it is getting more frequent. Transitions sometimes will open then crash when I try and apply a change in the transition. It seems more likely to work properly if there are no color corrections or vari speeds on either clip.
    I’ve thrown out the M100 preferences, reinstalled M100 & sucessfully run the M100 Test Pgm, used disk utility on the drives which found no permission or disk problems. I tried using the internal drive for the media on a new program & it still crashes. It runs fine in Boris Red 3.0 & Commotion 4.1. I might have not fully unistalled M100 as when I reinstalled it didn’t ask for a serial number. Any advice would be really appreciated.
    I have M100iXR vs 8.2.3 running Mac OX 10.4.8 with QT 7.1.3 on a G4 Dual processor 1.4.
    Ted Joyce replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
