Activity › Forums › Media 100 › M100HD – No audio output if captuing from in channels other that 1&2
  • M100HD – No audio output if captuing from in channels other that 1&2
    Posted by Bobby Mosaedi on March 10, 2006 at 6:51 pm
    Trying to acquire this HDV footage going through a miranda box… i have a flying cow with AES out going to channels 1&2 on the HDX junction box and aes coming out of the miranda box directly to channels 3&4 on the HDX box. When i go to audio input and select channels in 3&4 and go to acquire, i can see the levels coming in on media100’s meters, but there is no signal going to my flying cow for audio monitoring… is this a limitation of media100 hd? i thought it simultaneously sends audio out to all channels. Anyone else experience this?
    Floh Peters replied 20 years, 6 months ago 2 Members · 1 Reply
  • Floh Peters
    March 10, 2006 at 7:08 pm
    [Bobby Mosaedi] “is this a limitation of media100 hd?”
    It is a limitation, or a feature, as you like 😉
    Due to a hardware design you get while acquiring only the sound on the channels you use as an input. If you acquire on 3/4 you get the out on 3/4 during acquire. On 1/2 you will get the signal you send in on 1/2, even if you acquire 3/4. So don
