Activity Forums Media 100 m100 V12.7.1 wipes on MacPro 8 core 4Gb RAM
  • m100 V12.7.1 wipes on MacPro 8 core 4Gb RAM
    Posted by David Issko on September 25, 2008 at 6:09 am
    Just created some soft edge wipes of at least 1 1/2 seconds duration. Randomly, the wipe either starts a few frames too late or it finishes too early.
    In other words the start or end of the wipe does not start from the side of frame. It ‘jumps’ into frame partly started or finishes before it reaches edge of frame.
    Not a good look.
    Anyone else able to replicate this and if so, can this be patched ASAP please.
    Thanks very much
    David Issko
    David Issko replied 17 years, 11 months ago 3 Members · 3 Replies
  • Floh Peters
    September 25, 2008 at 6:13 am
    I never have seen this. What format/framesize/codecs are you using? Does the wipe render correctly, or does the problem also appear in a rendered wipe?
  • Gary Milligan
    September 25, 2008 at 10:11 pm
    Hi David,
    Check your transition settings – perhaps the “from/to” range is not 0-100.
    Gary
    This is me – this is what I do – https://web.mac.com/garymmw
  • David Issko
    September 25, 2008 at 11:21 pm
    Thanks guys,
    The codec I use is ProRez 422 in HD project from imported EX files No problem with other transitions. Happens in both preview mode & rendered mode in any direction. Transition setting is 0-100. One point I will mention is that the soft edge is very soft edge but that should not affect the transition.
    I will be trying again today after re-starting the system. Update in my next post.
    David
