Activity Forums Media 100 m100 transcoder crashing
  • m100 transcoder crashing
    Posted by Justin Wheeler on August 13, 2006 at 1:15 pm
    Hi Floh and others,
    My M100 transcoder is crashing Compressor and Cleaner. Do you have any idea why?
    I am transferring M100 self-contained media files from a Media 100 7.5.1 on a G4 with OS9 to Compressor on a G5 with OSX. I recently downloaded from the Media 100 website the Media 100 i
    Justin Wheeler replied 20 years, 1 month ago 4 Members · 4 Replies
  • Andrew Mehta
    August 13, 2006 at 9:53 pm
    I don’t really know the answer to this question.
    So Floh or someone else will probably give you a proper answer.
    (I’ve never used Compressor, and I only have a G4)
    Nonetheless, I’ll say two things:
    1) I have the Media100 Transcoder on OSX Jaguar, and have no problems with encoding Media100i 7.5 self contained movies with Cleaner 6.
    2) On the Media100 website, there appear to be a new set of codecs for download. My guess is these could replace the old transcoder, and you may find these work on the newer systems, where the transcoder would otherwise crash (of course I could be wrong – this is just a guess).
    Linkage is here:
    https://www.support.media100.com/KBSearch/kbDocument.aspx?id=379
    Of course, I could easily be wrong though.
    The Transcoder is still online also at:
    https://www.support.media100.com/KBSearch/kbDocument.aspx?id=193
    So maybe the codecs don’t replace it, but are for M100 itself.
    I’m not really sure.
    Well these are my two cents.
    Am sure someone else will come along and clear things up for you soon though, and correct me if I was mistaken in my second point.
  • Floh Peters
    August 14, 2006 at 7:47 am
    Yes, remove the transcoder and install the Media 100 codecs on your G5 (and either upgrade to V8.2.2a or install the codecs according to the instructions on your Media 100 i system also). This should fix the crashings.
  • Brad Jones
    August 14, 2006 at 4:43 pm
    Mine is crashing Cleaner too! I’m on a G4 Dual 800 and running OS X.3.9 and 8.2.3a
    J. Brad Jones
    BBB Communications
    http://www.bbbtv12.com
    http://www.wyshtv.com
  • Justin Wheeler
    August 16, 2006 at 7:00 am
    Thanks for the advice. It seems to not crash now with the new codecs.
    After a few compression tests however I find that exporting from M100 to Cleaner
