Activity Forums Media 100 M100 sd – hd -ae issues
  • M100 sd – hd -ae issues
    Posted by Lukkee Chong on June 13, 2006 at 6:45 pm
    Hi all,
    Working on a 16 x 9 project digitized using Media100sd 8.2.1. We then take the files to AE 6.5 on our G5 w/Media100hd for compositing/colour correcting etc. The ae project is set up for 16 x 9 lower field first and rendered using the M100 codec. It comes out with the jitters (like bad progressive video). The problem is not as pronounced when we use the animation codec. When we do some of the renders on the SD system it is smooth. How can we get it smooth on the HD system?
    Thanks for any input,
    lc
    Lukkee Chong replied 20 years, 3 months ago 2 Members · 7 Replies
  • 7 Replies
  • Floh Peters
    June 13, 2006 at 6:51 pm
    So what
  • Lukkee Chong
    June 13, 2006 at 6:55 pm
    Hi Floh,
    We are NTSC, 720 x 486 in AE widescreen with the clips interpreted as ntsc widescreen lower field first rendering to the Media100 720 codec in on the Media100HD system. Output module is set up for lower field first in AE.
    lc
  • Floh Peters
    June 13, 2006 at 6:59 pm
    Are you sure that you are NTSC widescreen 720*486? The default NTSC widescreen setup is 720*480, which would explain the results you
  • Lukkee Chong
    June 13, 2006 at 7:03 pm
    Yes, very sure. I have checked it several times also done multiple renders of several variations. I will keep on trying.
    lc
  • Floh Peters
    June 13, 2006 at 7:05 pm
    Send me a AE project file (without the media) with something in the Render Queue, and I will have a look.
  • Floh Peters
    June 13, 2006 at 7:43 pm
    Lukkee,
    your Comps are 720*480 instead of 720*486 which gives you the problem you are seeing. Go to your comp settings (CMD-K) and set them to 720*486 widescreen
  • Lukkee Chong
    June 13, 2006 at 8:04 pm
    Thanks Floh, I will re-render. I guess it pays to double check everything (everyone!)
    lc
