Activity Forums Media 100 M100 on Mac Cylinder machine
  • M100 on Mac Cylinder machine
    Posted by Paul Crowe on April 28, 2014 at 6:39 am
    Hi there,
    for serveral reasons I’m looking into upgrading my trusty mac pro silver tower to a cylinder machine (possibly). Before I do I just wanted to check if anyone has had experience running M100 on this machine or has heard of any possible issues?
    Obviously expansion cards for external AJA boxes etc are a no-go. I’m just thinking it’s time to put these to rest anyway. There’s pretty much always an alternative to getting stuff into the computer these days (a thunderbolt connected box perhaps?).
    ANyway any thoughts would be much appreciated. Before I drop a whole bunch of cash on this machine.
    Cheers
    Paul
    Floh Peters replied 12 years, 2 months ago 5 Members · 5 Replies
  • Jim Wiseman
    April 30, 2014 at 3:16 am
    I have Media 100 2.1.5 running on a Late 2013 Mac Pro as described below. Running on Blackmagic Ultrastudio 4K via Thunderbolt 2. Have not done extensive testing other than to open previous projects created on 2.1.3 and 2.1.4. But everything seems OK. I have an AJA LHi, but will probably be leaving it in the 2012 Mac Pro tower. I have an OWC Helios 2 chassis it should work in with M100, but I will probably leave well enough alone there. Hope this helps. The indications are good though with my setup.
    Jim Wiseman
    Sony PMW-EX1, Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Pro X 10.1.1, Final Cut Studio 2 and 3, Media 100 Suite 2.1.5, Premiere Pro CS 5.5 and 6.0, AJA ioHD, AJA Kona LHi, Blackmagic Ultrastudio 4K, Avid MC, 2013 Mac Pro Hexacore, 1 TB SSD, 64GB RAM, 2-D500: 2012 Hexacore MacPro 3.33 Ghz 24Gb RAM GTX-285 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 16GB RAM 250GB SSD
  • Gerry Condez
    April 30, 2014 at 8:07 pm
    Im using Sonnet thunderbolt expansion for the aja kona3g and works fine and have a matrox mxo2 max as a backup for on location editing. It should work perfectly on the cylinder, im just using a new macmini for now.
  • Floh Peters
    May 14, 2014 at 11:37 am
    The new MacPro is working great for me so far. I have seen some issues with XDCam Transfer which I have to investigate. But other than that, using a Sonnett Expansion Chassis and a Kona LHe+ in the current setup, everything is fine.
  • Jaeson Koszarsky
    July 1, 2014 at 3:44 pm
    Which sonnet chassis are you using?
    We have KONA LHi boards.
  • Floh Peters
    July 1, 2014 at 4:14 pm
    We have 2 Sonnett Echo Express SE II for 2 2013 Mac Pros, one with a LHe Plus, and one with a LHi. Both chassis also contain FibreChannel cards for our SAN. This setup works extremely reliable for us.
    One thing you should be aware of with the chassis, though, is that they don´t accept full-length PCI express cards. The older Kona3 for example will not fit in there.
