Activity Forums Media 100 M100 Color Corrector Crashes
  • M100 Color Corrector Crashes
    Posted by Paul Friedli on July 26, 2014 at 8:28 am
    I Have a an issue when editing files in M100 using the ColorFX tool.
    Every 3-4 times it crashes the M100 App when exiting the ColorFX.
    Setup is:
    2011 MacPro
    OSX 10.7.5
    Apple 4GB FC Card
    Kona LHi (Drivers are Up to date)
    M100 2.1.3 (same issue with 2.1.5)
    Files are ProRes 422HQ full HD 50i originating from P2 and XDCAM HD.
    I’ve setup the Computer from scratch, also tried with osx 10.9.2.
    Anybody has an idea?
    Thanks for any suggestion
    Paul Friedli
    Paul Friedli replied 12 years, 1 month ago 3 Members · 3 Replies
  • Robert Stone
    July 26, 2014 at 9:18 pm
    Aloha Paul – I’m sure you probably re-installed the application. Did you try deleting the color FX preferences? Maybe something buggy in there.
    Blessings,
    Robert C. Stone
    https://HippieFilm.com
    https://MauiTVSpots.com
  • Floh Peters
    July 31, 2014 at 3:06 pm
    Strange, I use the Color Correction a lot, and I never see crashes with it. What kind of CC do you use?
  • Paul Friedli
    August 7, 2014 at 3:02 pm
    Thanks for your replays.
    Im Using the standard colorful from M100. I have trashed the prefs. The color preset seem to be stored in the project as well. I can use the same project on my Support laptop and it works fine. Could it be an issue with some other software like an old AE CS3?
