Activity Forums Media 100 M100 1.5.1 Released
  • M100 1.5.1 Released
    Posted by Matt Mullen on April 6, 2010 at 8:34 pm
    What’s new in Version 1.5.1?
    Media 100 Suite 1.5.1 incorporates the following fixes and enhancements from version 1.5:
    NTSC Timecode for imported WAV and BWF files with embedded timecode has been corrected.
    Batch export of multiple programs now produces the expected results.
    Volume search for media relink has been updated for better compatibility with certain network volumes.
    Conforming media from the new standards 720p25 or 720p29.97 now produces the correct results.
    The application no longer shuts down during launch or export when it encounters an incompatible QuickTime component.
    New commands “Ripple Delete in Track” and “Ripple Delete.”
    The Ripple Delete commands delete a marked range of frames and shift everything after the range to the left. To use Ripple Delete in Track, first mark the beginning of the range you want to delete with the Mark-In command (F1), and mark the end of the range with the Mark-Out command (F2). Then select the track containing the clip(s) you want to delete by clicking on the green ball at the left of the program window. The Ripple Delete in Track command is now enabled in the Program menu. To use Ripple Delete, which affects all tracks, hold down the option key.
    The update is available by downloading and installing the trial from the downloads page:
    https://www.media100.com/support/downloads.php
    The release notes area here: https://www.borisfx.com/download_files/Media_100_Suite_1_5_1_Release_Notes.pdf
    Matt Mullen replied 16 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
