Activity Forums Audio m audio Flying Cow D/A audio level
  • m audio Flying Cow D/A audio level
    Posted by Eric Chase on June 5, 2013 at 9:43 pm
    I’m going from AES digital signal -20db out, and the analogue volume level XLR out put is 4-5db weaker in volume. it’s the same on all versions.
    yes, I’ve tested out the AES signal against a digial deck and it works fine. it’s only the Flying Cow that seems to cut the volume slightly from a perfect 0db output.
    Anyone know how to fix this?
    Eric
    Ty Ford replied 13 years, 2 months ago 2 Members · 3 Replies
  • Ty Ford
    June 5, 2013 at 10:34 pm
    Hello Eric and welcome to the Cow Audio Forum.
    Is there any possibility that you are using an unbalanced cable to whatever metering you’re seeing the reduced level on? A malfunctioning balanced cable with only one working signal leg would drop about 6 dB.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
  • Eric Chase
    June 6, 2013 at 3:14 pm
    For sure it’s a balanced cable. I’ve also tested the cable with other equipment.
  • Ty Ford
    June 6, 2013 at 4:17 pm
    Eric,
    My guess is it’s a calibration issue or a level issue.
    I’d suggest contacting the mfgr.
    Regards,
    Ty Ford
