Activity › Forums › Apple Final Cut Pro Legacy › M-Audio Fast Track USB and FCP Voice Over Tool
  • Rafael Amador
    December 1, 2007 at 12:52 pm
    What are really important are the steps before your audio gets digitized. I mean the mic you use and the ambience where you make your recording. If you get a good sound in to your M-Audio Fast Track you will get a perfect voiceover.
    Rafael
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
  • Christopher Tay
    December 2, 2007 at 1:09 am
    Hi Rafalaos,
    Thanks for your reply. We will ensure that the mic level is properly pre-amped and it will be a good signal as it is coming from a v/o room.
    Basically I just need to confirm that FCP will recognise the M-Audio Fast Track USB device in the Voice Over Tool.
    -chrispy
  • Rafael Amador
    December 2, 2007 at 2:59 am
    To make sure that your Mac recognice the Fast Track USB, plug it and open the System Preferences>Audio>Input.
    If you can see the name of the device in the list will works. If you set the Fast Track USB to record 16b/48Khz, perfect for FC.
    rafael
  • Christopher Tay
    December 2, 2007 at 3:06 am
    Thanks !
    -chrispy
