Activity Forums VEGAS Pro M-Audio 410 – to any users – static noise
  • M-Audio 410 – to any users – static noise
    Posted by Kip Count on February 29, 2008 at 1:31 pm
    My M-Audio 410 is noisey. What I mean is, through my monitors, I can hear static and buzzing, it’s quiet.. but it’s that annoying frequency that kinda hurts your ears. I can hear it when there is no sound playing and the 410 is idle. Then I hear a different static when I move my mouse. When the processor gets really intense for a second, it’ll get quiet, then back to the static again. Definitely sounds like noises are getting out on the firewire that shouldn’t be.
    I have installed the latest driver from M-Audio. (And reinstalled it once just to see if that would help, but no go).
    Anyone else have any problem like this?
    BTW,
    I am running…
    A8N-SLi motherboard
    Athlon X2 3600+ cpu
    2GB PC3200 RAM
    ProTools 7.4
    Sony Vegas Pro 8.0b
    M-Audio 410
    nVidia 7300le video card
    Three 7200rpm drives
    Rick Mac replied 18 years, 6 months ago 3 Members · 2 Replies
  • Neil Moxham
    February 29, 2008 at 6:55 pm
    I think you have a grounding problem.
    I have had this problem before.
    the problem isnt the 410. its bad data
    What happens if you disconnect the speakers, hook up headphones
    listen to your audio then. If its quiet…cool
    While you have headphones on…plug in a speaker….do you hear it comeback?
    If so…
    Are you using balanced (tip/ring/sleeve) 1/4″ cables to go between the 410 and the speakers. Balance lines will not attract erronious magnetic fields. but wont solve a grounding problem.
    Try ground lifts on your speakers. Also Make sure that your speakers are plugged into the same circuit that the computer is.
    Once I had to disconnect the audio wire that went from my CD/DVDrom drive to the motherboard. Crazy…I know but it worked. worstcase…try it
    Somekind of digital info loop that jumped onto the the wrong bus.
    Zip
    Zipedit
  • Rick Mac
    March 1, 2008 at 12:16 am
    [Neil Moxham] “Try ground lifts on your speakers. Also Make sure that your speakers are plugged into the same circuit that the computer is.”
    Lifting your power ground pin is not a smart thing to do.
    It may fix a ground-loop but could leed to a fatal
    shock. The best thing to do is to get all your gear on the same circuit and verify the integrity of your cables.
    In a balanced line (tip ring sleve) you can lift the shield (ground) wire on one end to break a ground-loop.
    If you have a have a unbalanced line hum and buzz will come from a broken or poor ground wire.
    You can also get what is called induced hum and buzz from
    placeing your gear to close to a strong megnetic field such as
    a TV Monitor. To fix this, move your gear away from the megnetic field. Lastly lighting dimmers can throw all kinds
    of noise into your gear. Get rid of it.
    Regards, Rick.
    Rick Mac
    Director of Audio Production
    TCT Network – Directv 377
