Activity › Forums › Adobe After Effects › Lux Question…
Lux Question…
Posted by Captain Mench on June 3, 2006 at 5:44 pmMy spot lights are visible thru my graphics… am I missing a step?
Here’s what my comp looks like…
1. Lux Reach (locked) — not that adding reach seemed to help any…
2. Adjustment Layer w/Lux
3. Light3
4. Light2
5. Light1
6. Spot Light
7. Camera
8. Logo
9. Floorhttps://homepage.mac.com/captmench/TBPLux264.mov
CaptM
Captain Mench replied 20 years, 3 months ago 3 Members · 6 Replies -
Captain Mench
June 3, 2006 at 5:58 pmOk — I figured out I could add additional REACHes and this stopped my mini spots from shining thru…
BUT — I’d really like the opening to look like the LOGO is solid and the light is building AROUND it.
CaptM
Mylenium
June 3, 2006 at 6:36 pmLux does not calculate volume shadows. You have to duplicate your logo plate layer and use it as a mtte on the Lux layer.
Mylenium
[Pour Myl
Captain Mench
June 3, 2006 at 7:19 pmUgh — sorry… I don’t understand.
IF I put it above the Lux Adjustment Layer it works great from behind… but it messes with the front lights.
When I put it below (behind) the original Logo Plate the Adjustment layer still affects it.
I tried messing with Track Matte… is that what I should be using?
CaptM
Jonathan Miller
June 3, 2006 at 8:47 pmNow you’re getting it.
Like you mentioned, it all works when the Lux layer is placed below your graphic. But it doesn’t work because then it messes up the other lights after the camera move.
So, what I would recommend is splitting your logo “billboard” layer into two layers just at the point where it nearly dissapears when it’s halfway through the camera move. Place the layer above the Lux before the split and below the Lux after and it may look more realistic.
Good luck!
Jon
TreeLine Productions
Fort Collins, CO USACurrently producing these popular podcasts:
Captain Mench
June 3, 2006 at 9:13 pmI’m actually fine with it now… it moves fast and the audio helps:
https://homepage.mac.com/captmench/TBLogo2.m4v
CaptM
