Activity Forums DaVinci Resolve LUT usage
  • LUT usage
    Posted by Sascha Haber on April 12, 2011 at 12:36 pm
    Hi there,
    I got my hands on a nice Panasonic and would like to use a LUT i built in Resolve to (dont kill me) make the Panasonic look as close as possible as the Cinema display.
    So I did the Lut generation in Resolve, works well but now i would like to load it into the video output only.
    I would like to keep the image on the UI unchanged.
    Is that possible ?
    Do i need to load the LUT into the Blackmagic card maybe ?
    A slice of color…
    DaVinci 7.1 OSX 10.6.6
    Dual Xeon 2,4 RAM 24 GB
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
    Adam Hendershot replied 15 years, 4 months ago 8 Members · 11 Replies
  • 11 Replies
  • Tim Farrell
    April 12, 2011 at 8:29 pm
    Hi Sascha,
    Have a look at BM HD Link.
    https://www.blackmagic-design.com/products/hdlink/
    Features include 3D LUT.
    Hope this helps,
    Tim
  • Illya Laney
    April 12, 2011 at 8:36 pm
    Can you load a LUT created in Resolve into the HDLink though?
    twitter.com/illyalaney
  • Tim Farrell
    April 12, 2011 at 8:56 pm
    Yes, both use the .cube format.
  • Blase Theodore
    April 13, 2011 at 3:53 am
    wait, so if I wanted to build a lut that covered my primaries targets and gamma/whitepoint tweaks, I could build it in Resolve, and load it to my HDlink? Or is this more for using legalizing luts with full range mat’l?
  • Tim Farrell
    April 13, 2011 at 8:09 am
    Yes, I believe you could do that. Perhaps one of the BM guys can confirm.
  • Sascha Haber
    April 13, 2011 at 9:15 am
    Or to answer my question, I can not.
    I need to buy a box .
    Awesome.
    A slice of color…
    RAID0 8TB eSata 6TB
    GTX 285 / GT 120
    Extreme 3D+ WAVE
  • Mikhail Puzyrev
    April 13, 2011 at 9:56 am
    You better take it for test first. I have HDlink pro and it works with my old pioneer plasma, but doesn’t with new Panasonic TH-42PF20. It shows PAL but none of the HD formats. Neither from FCP nor from Davinci. I’ve sent it to local bm reseller (who sold me that) and as they checked hdlink, their response was – the box is ok – your plasma is wrong. When decklink connected to plasma through hdmi out – everything works, from PAL to 1080p.
  • Vladimir Kucherov
    April 13, 2011 at 5:09 pm
    I had some problems (although with the G25 plasma) when I first got the HDLink and problems stemmed down to the Display Port to HDMI adapters. They actually were very helpful and even provided beta firmware that resolved the issue. Since the latest updates everything has been going well, although sometimes I have to switch between video output modes to get the picture to show up.
    Not sure if your issue’s completely different but hope that helps.
  • Mikhail Puzyrev
    April 13, 2011 at 6:01 pm
    I’ve flashed it with fresh firmware – it helped with eizo cg241w but not with panasonic. Checking uncheking EDID button has no effect. Tried both DVI-DVI connection and DVI-HDMI, tons of cables, nothing worked out. Switching to PAL – picture ok! Switch 1080, 720, p, i, psf – plasma switches to “no signal” mode.
  • Jake Blackstone
    April 25, 2011 at 12:03 am
    Same here…
