Activity Forums DaVinci Resolve LUT Not Exporting
  • LUT Not Exporting
    Posted by Eric Klassen on February 18, 2015 at 10:35 pm
    I have a 3D LUT set up to see a 2020 color space on a Rec709 monitor. When I go to deliver the clips, Resolve seems to get causght up: the images are losing the grading work and they appear very washed out. I’ve tried exporting to a QT ProRes422 and an uncompressed EXR with no luck.
    Can someone explain what’s happening and why won’t Resolve retain my color grading work on export?
    Eric
    Eric Klassen
    Tiago Azzi replied 6 years, 11 months ago 2 Members · 2 Replies
  • Eric Klassen
    February 20, 2015 at 7:18 pm
    I found that this LUT has a bug. When the “Highlight” button was activated, Resolve shut off all the grading work on the export. In order to grade properly with the LUT, the Highlight had to be off. Wierd…
    – Eric
    Eric Klassen
  • Tiago Azzi
    October 16, 2019 at 8:58 pm
    Hi Eric, I am going crazy with the same issue… Where is this highly button you are talking about?
    thank You
