Activity › Forums › DaVinci Resolve › Lut highlights
  • Lut highlights
    Posted by Stig Olsen on September 18, 2012 at 5:20 pm
    Hi, When working on r3d I do my main exposure adjustments prior to the LUT. Sometimes I need a good key for adjusting highlights and therefore working after the LUT. Some adjustments (like highlight adjustments) will not work properly after the LUT so Im getting stuck with a bad key. How do you deal with that?
    Stig Olsen replied 14 years ago 5 Members · 8 Replies
  • 8 Replies
  • Sascha Haber
    September 18, 2012 at 7:54 pm
    Using a second input or a parallel node
    A slice of color…
    DaVinci 9b3 OSX 10.8
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    Colorist / Aerial footage nerd
    https://vimeo.com/saschahaber
  • Stig Olsen
    September 18, 2012 at 8:30 pm
    It does not help because the key need an input from after the LUT.
  • Stig Olsen
    September 19, 2012 at 10:37 am
    Anyone?
    I need to make a key from a node after the lut but to adjust the keyed part properly I need to do have access to the source or a node prior to the LUT.
    Stig
  • Chris Martin
    September 19, 2012 at 5:33 pm
    What is the LUT for?
  • Ola Haldor voll
    September 20, 2012 at 6:52 am
    Try using a Parallel node. You can select what node is the source for the node, or even the main video source as well.
  • Rohit Gupta
    September 20, 2012 at 6:59 am
    Or you can just add a node, feed the input from the source, and only use this node to output a key. This is assuming you don’t want to mix back any of the original image. If you need to mix back any of the original image, you can use a layer mixer as well.
  • Stig Olsen
    September 20, 2012 at 7:34 am
    Hi, I did not explain myself good enough. The key need its source from a node after the LUT (to have s clean key). To adjust this key I need the source from the node before the LUT. These sources need to be connected somehow.
  • Stig Olsen
    September 20, 2012 at 9:00 am
    It did work by doing this:
    – Create a corrector node after the LUT to have a clean key
    – Create a parallel node, but change the input to a node prior to the LUT
    – Feed the key into the parallel node
    – Invert the key or add an outside node to adjust.
    This way it will give a clean key (made from after the LUT) and all the corrections will affect the data prior to the LUT but feed it back later in the chain.
    Stig
