Activity Forums Avid Media Composer LUT For Iphone 13 Pro clips
  • LUT For Iphone 13 Pro clips
    Posted by Dan Crouch on June 1, 2022 at 6:05 pm
    Using Shutter Encoder, I have managed to convert my iphone 13 footage into pro res, I used colour space 709 when converting the footage. I can AMA link it and succesfully transcoded it into my project.
    Can anyone advise me on the LUT I should use on the clips?
    Thanks in advance for any advice.
    Dan Crouch replied 4 years, 3 months ago 2 Members · 2 Replies
  • Pat Horridge
    June 1, 2022 at 6:33 pm
    If you’ve converted to rec709 then you should need any LUT.
    Possibly full range levels to legal levels I’d think.
  • Dan Crouch
    June 6, 2022 at 10:36 am
    Thanks for the reply Pat, much appreciated.
    I think you meant to say should ‘not’ need a LUT.
    That’s good news as it does look pretty good ingested at rec709.
    I jusy wanted to be sure it’s the best it could be, which it seems it is.
    Thanks again for the reply.
    Dan.
