Activity Forums Apple Final Cut Pro Legacy Lut Buddy & technicolor cine style crashing FCP
  • Lut Buddy & technicolor cine style crashing FCP
    Posted by Toby Heslop on July 22, 2011 at 11:12 am
    Trying to use Magic Bullet Lut Buddy within FCP 7.0.3 with the Technicolor cine style Lut.
    everything is transcoded to ProRes, and when I try to render with the Lut & Lut Buddy plug in, everything crashes.
    WTF, I thought this pipeline was working. FCP just crashes upon initial trying to render.
    Tryed to export the LUT and re-import. no luck, checked the Magic Bullet site, no love.
    What’s a project to do to use HDSLR with Technicolor Stylizes and tapping the LUT via MB Lut Buddy
    Any surgestion to fix the issue?
    try to reinstall, repair permissions, restart system, no love!
    Shachar Langlev replied 13 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • Toby Heslop
    July 22, 2011 at 11:16 am
    Process: Final Cut Pro [986]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 7.0.3 (7.0.3)
    Build Info: FCPApp-1008261348~8
    Code Type: X86 (Native)
    Parent Process: launchd [172]
    PlugIn Path: /Library/Plug-Ins/FxPlug/LUT Buddy.fxplug/Contents/MacOS/LUT Buddy
    PlugIn Identifier: com.RedGiant.lutBuddyFxPlug
    PlugIn Version: 1.0 (1.0)
    Date/Time: 2011-07-22 21:14:58.303 +1000
    OS Version: Mac OS X 10.6.8 (10K540)
    Report Version: 6
    Interval Since Last Report: 181393 sec
    Crashes Since Last Report: 11
    Per-App Interval Since Last Report: 235775 sec
    Per-App Crashes Since Last Report: 11
    Anonymous UUID: 56FB150A-0A02-46DE-A2E1-7D64A283E609
    Exception Type: EXC_CRASH (SIGABRT)
    Exception Codes: 0x0000000000000000, 0x0000000000000000
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
  • Ken Pugh
    July 22, 2011 at 1:53 pm
    Doesn’t help you – but I’m also using LUT Buddy with ProRes transcoded footage (from Canon 60D) and having no problems. Although it does render 5 times slower than using Colorista or the three-way. It’s quite easy to get the look using these tools rather than the LUT anyway so you wont loose much if you decide not to try and get it working.
    Best,
    Ken.
    8 core 10.6.7 FCP 7.0.3
  • Alex Legrand
    September 11, 2011 at 3:42 pm
    Hi Toby,
    Unfortunately, I cannot help you either, but I have the exact same crash than you have.
    Did you find where the problem is?
    If you did, could you please let me know? This thing just drives me crazy.
    Best
    Alex
  • Toby Heslop
    September 11, 2011 at 9:51 pm
    I’ve stopped using it now, Noe I use an s curce in colorista2
  • Alex Legrand
    September 12, 2011 at 7:10 am
    Thanks for answering.
    May I ask you how you do that?
    Are you making your own curve, or are you using the technicolor curve in a different plug in?
    Best
    Alex
  • Toby Heslop
    September 12, 2011 at 10:46 pm
    colorista 2
    Scroll down to the Master grade section
    Create an S curve with as much punch as you need, use the rest of the plugin to tweak up to your liking
  • Francis Levy
    November 20, 2011 at 9:25 am
    Hi guys! I was having the exact same problem, it is fixed by downloading the Technicolor fix here:
    https://www.technicolor.com/en/hi/cinema/filmmaking/digital-printer-lights/cinestyle
    It is a .mga file that you need to import from the LUT buddy instead of the previous faulty .lut file.
    Francis Levy
    Colima, Mexico
  • Shachar Langlev
    October 15, 2012 at 2:52 pm
    How do you inport the .mga file to FCP ? I tried unsuccessfully
    Panasonic AF100:Canon 7D: contemplating Scarlet 😉
    FCP 7 editor n teacher
    Freelancer DP
    Director – my last film is at
    https://www.wix.com/folkswagon/film
