Activity › Forums › Adobe After Effects › Lumosity add – drawings over live video…?
Posted by Grant Wilber on January 30, 2013 at 4:00 pmI was curious how this kind of thing is done:
https://www.youtube.com/watch?v=ZZpKBDIv1XUThat sort of drawing, jiggly, kind of feel? Both some of the more simpler things (lighting_ to something a bit more involved (Like the last shot with the lines reacting to her hands). Any push in the right direction to start learning would be great.
Mo Hirsi replied 13 years, 7 months ago 6 Members · 7 Replies -
Roland R. kahlenberg
January 30, 2013 at 4:12 pmMask a Solid and add Scribble, Turbulent Displace and then Posterize Time. Animate Turbulent Displace’s Evolution property and set Posterize Time to 7fps. Tweak the other properties to get your desired results.
HTH
RoRKIntensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7) -
Tudor “ted” jelescu
January 30, 2013 at 5:20 pmAnother way of doing this that I find easier since I tend to design my graphic elements in Illustrator is to create 3 or 4 versions of the same element with slight variations on separate layers(really easy to do with a vector graphic), import that in AE as a sequence and loop it. Then you animate the loop layer to do whatever move you need. To have the element/elements follow a head or hand movement you can track the move, link all graphic elements to a Null and apply the track to that Null.
Tudor “Ted” Jelescu
Senior VFX Artist -
Chris Brett
January 30, 2013 at 5:54 pm— Hi —
——–reckon its probably a combination of techniques —
– some of it looks like frame by frame animation to me or some version of it – checkout ‘atoms found head’ and ‘bright-idea sequence’ ………..
……. or are you guts saying that these others methods do the same thing ?? ………
—– chris —-
Vishesh Arora
January 30, 2013 at 7:27 pmGrant
See the example below:
5343_turbulentdisplacetimeexpression.zip
Vishesh Arora
3D and Motion Graphics Artist
Films RajendraBlog:
https://digieffects.wordpress.com2011 3D Demo Reel:
https://www.youtube.com/watch?v=lHPgIJU_BR8 -
Mo Hirsi
February 16, 2013 at 3:44 amsup grant,
did you manage to make such a thing. was planning on doing something like this for a short video. didnt know where to start though..
get back to me on with some tips, tutorial etc
speak soon
Vishesh Arora
February 16, 2013 at 10:40 amMo
Check my earlier post. I have created an example. It may help.
Vishesh Arora
Films RajendraBlog:
