Activity Forums Maxon Cinema 4D luminance of a material does not light close pyrocluster clouds
  • luminance of a material does not light close pyrocluster clouds
    Posted by Helmut Ringl on February 8, 2016 at 11:07 pm
    Hi guys
    I am new to this forum, so I say hi to all! Got stuck with c4d problem ..
    background: want to make cloud of pyroclusters, a lightning strike originates out of the cloud. the strike has a yellow material with luminance 500%
    it lights the ground where it strikes but not the pyroclusters cloud …
    Global illumination is on
    it works to light the pyroclusterclouds with ordinary lights in c4d
    I have tried: different rendersettings, many different pyrocluster settings(like luminance), ….
    here is a test scene that demonstrates the problem. the material on the sphere should shed light on the clouds, but does not
    9765_pyrocluster.c4d.zip
    Can someone help me with this problem?
    Thanks in advance
    helmut
    Helmut Ringl replied 10 years, 6 months ago 2 Members · 6 Replies
  • Adam Trachtenberg
    February 9, 2016 at 5:30 pm
    Pyrocluster doesn’t seem to support GI. I think you’ll have to fake it with a colored light if you want to go with Pyro. You’ll also have to enable scene illumination in the Pyro material.
  • Helmut Ringl
    February 9, 2016 at 9:59 pm
    Hi Adam
    thanks! I hoped that there is a way ..
    here is the desired image(without illumination of the cloud)
    I dont have to stay with pyrocluster for the cloud, is there another reasonable way?
    the fake light works, but I want to make an animation with several ozillating strikes, so it would be complicated.
    I tried to put an reflector beneath the cloud, but this does not work either
    helmut
  • Adam Trachtenberg
    February 9, 2016 at 11:19 pm
    The only way I know of is to animate a light or lights to get the effect. Shouldn’t be that difficult. Use colored lights with Inverse Square falloff.
  • Helmut Ringl
    February 10, 2016 at 11:15 am
    Adam, I followed your suggestion
    it works, thanks!!
    although i limited the lights to the start and endpoint of the lightning, intersections with the clouds are not illuminated . to do this, I would have to modifiy the phyton skript and add lights along the spline, which would cost too much time for now
    here is the result, still very basic but a start
    helmut
  • Helmut Ringl
    February 11, 2016 at 1:18 pm
    one last time 😉
    would it be possible with a different renderer?
    maybe furryball?
    helmut
  • Helmut Ringl
    February 15, 2016 at 10:28 am
    so …
    furryball and octane did not render the pyrocluster at all …
    maybe my fault, did not spend much time with it
    I got a solution:
    I converted the phytonskript bolt to a single polgyon object
    assigned an area light with inverse square falloff
    two hours fine tuning
    you dont even need GI for it
    helmut
