Activity Forums Apple Final Cut Pro Legacy luminance & gamma problems
  • luminance & gamma problems
    Posted by Hernan Torres on November 5, 2005 at 4:58 pm
    Hi everybody
    I’m having right now a very serious problem with my FCP 4.5
    I captured video using my AJAla video card, using the YPbPr Betacam 10 bit NTSC, when I playback the captured video on the viewer, everything is aparently fine but when I stop the clip all the highlight go really high and the image is burned on the white peaks.
    Curious thing is that I need this material for fx work on AEffects, so I export the material with NONE compression, and the problem with the levels remain. Allthe whites go high and the image is burned.
    The video levels of the original footage are very high, but no totally ilegal. whites are a little bit over 100%.
    if anybody can help please I am in a hurry.
    Hernan Torres
    Hernan Torres replied 20 years, 10 months ago 2 Members · 2 Replies
  • Andy Mees
    November 6, 2005 at 1:45 pm
    do you have Range Check enabled ? we’ve had some issues with that function … pretty much what you’re describing.
    (during playback the levels are as expected, but when stopped theres a big luma shift)
    if so, turn off Range Check (control z toggles it on and off)
  • Hernan Torres
    November 7, 2005 at 1:40 pm
    yes I have the luma shift that you describe, but turning off the range check doesnt solve the problem. I digitize the material in an AVID and I dont have the kind of problems.
    I am still trying to figure out what is happening
    Thanks a lot
