Activity Forums Adobe Premiere Pro Lumetri effects faulty after upgrade.
  • Lumetri effects faulty after upgrade.
    Posted by Kevin Reiner on November 26, 2013 at 5:38 pm
    I had project that I did a month ago on Premiere 7.0 using Lumetri to read a LUT file for Alexa footage. Today I tried to open it in Premiere 7.1 and the lumetri effect caused the video clips to be unreadable. I had to delete each instance of the plug-in and re-apply (5 sequence, dozens of clips, big PITA). So the plug-in is working but it is not transferring correctly from previous versions, at least for me. Is this a known issue? Anyone else encounter this?
    I did a complete uninstall and re-install of the apps using CC Cleaner, but it still messed up.
    -Kevin
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    Nvidia Quadro 4000
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.8.4
    FCP 7
    Premiere CC
    After Effects CC
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
    Kevin Reiner replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
