Activity › Forums › Adobe After Effects Expressions › luma to drive animation of multiple comps
Posted by Andy Acourt on May 29, 2012 at 12:19 pmHi, I trying to animate the scale of an array of comps from a background fractal map. So for instance if the luma of a the section of fractal behind a particular comp was 100% white that comp’s scale would be 100%
Thanks in advance
Andy Acourt replied 14 years, 3 months ago 3 Members · 5 Replies -
Wim Bruyninckx
May 29, 2012 at 1:07 pmHi,
not sure of this will help you but;
I would suggest to use the nifty expression sampleImage() in the scale property layer
of each comp you want to scale in your array :the expression would be:
100*[thisComp.layer(“GreyscaleMap”).sampleImage(position)[0],thisComp.layer(“GreyscaleMap”).sampleImage(position)[0]]position = the position of your current comp you want to scale
where GreyscaleMap = your fractal map…
multiply it by 100, because sampleimage returns a value between 0 and 1.Kind Regards
Wim
graphic designer / illustrator
https://www.flickr.com/photos/wixwix/
https://www.wimbr.be -
Dan Ebberts
May 29, 2012 at 1:21 pmIt would probably be like this:
target = thisComp.layer(“background”);
rgba = target.sampleImage(target.fromComp(toComp(anchorPoint)), [.5,.5], true, time);
luma = rgbToHsl(rgba)[2];
[luma,luma]*100Note that this is set up for a 1-pixel sample–you might want a larger area, depending on your setup.
Dan
Andy Acourt
May 29, 2012 at 4:24 pmthanks for this, unfortunately I cant get it to work and I’m sure its me.
the fractal is on layer 1 and called “GreyscaleMap”
the comp I want to scale is on layer 2 and called “comp”
I’ve applied the script to scale property of the “comp” layerand thats where my understanding falls apart – any more help would be greatly appreciated.
thanks
Wim Bruyninckx
May 29, 2012 at 6:21 pmmake sure you precomposed the fractal layer, otherwise it won’t work
Andy Acourt
May 29, 2012 at 9:11 pmthanks for both of your help, especially Dan, it worked in the end. The problem was the fractal map had 3D turned on. As soon as I turned it off the script worked.
