Activity Forums Adobe After Effects Luma shift clipped when imported
  • Luma shift clipped when imported
    Posted by Scott Robert on June 9, 2009 at 6:29 am
    Importing a bright clip into after effects, the color and luma values over 100% are clipped as if a Broadcast Safe filter has been applied.
    If I export from FCP as Apple Prores (HQ) and re-import it, it’s fine.
    If I import it into After Effects and export it back to FCP as Apple Prores (HQ), all the values are clipped away over 100% in the vetroscope. I lose my highlights.
    I have Mac Pro 3.0, latest After Effect CS4 and FCP. The latest Quicktime. AJA Lhe HD card.
    Any help would be appreciated.
    Roland R. kahlenberg replied 17 years, 3 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    June 9, 2009 at 12:14 pm
    This issue has been posted on a number of occasions. Try the COW Search function.
    Cheers
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Scott Robert
    June 9, 2009 at 4:46 pm
    I take it that your sick of this. I’m pretty sure I did try and searched the forum before posting a same topic. I’ll try another forum.
    June 9, 2009 at 5:06 pm
    [Scott Robert] “I take it that your sick of this”
    Apparently not as much you. 😉
    I’ve never used ProRes so I couldn’t give you the type of answer you were expecting. But I did point you to a source where you could possibly get an answer that was suitable. I’ve seen a few threads here with similar issues as yours and that is why I made the suggestion.
    Besides, there are other users here that may give you a better answer. But until then, a COW search is truly your best bet.
    Cheers
    RoRK
