Activity › Forums › Adobe Premiere Pro › luma key?
luma key?
Posted by Raine Parrish on October 8, 2005 at 2:43 pmhello-
i plan to shot an actor, inside a car in my dark garage, fake some wind and passing car headlights, and then do a composite with moving footage outside the car windows. think “sin city”.
is it possible to pull the key in premiere? and if so, may i ask for directions on hos to do this- as i have never attempted a composite shot before.
thanks
rpCraig Howard replied 20 years, 11 months ago 3 Members · 5 Replies -
Aanarav Sareen
October 8, 2005 at 6:27 pmIt really depends on how you light the shot. Can you post a screenshot of the image?
Aanarav Sareen
Adobe Certfied Expert, Premiere Pro
https://www.asvideoproductions.com/video -
Raine Parrish
October 8, 2005 at 7:35 pmi haven’t shot any footage yet- trying to gather info to figure out the lighting need- since it’s suppose to imitate night time- perhaps i should try to put up blue or green tarps around the background to key off? since the inside of the car will be dark except for the few points of light- trying to key off the black or white might be a killer? any suggestions regarding this attack- will be much appreciated!
Aanarav Sareen
October 8, 2005 at 7:41 pmThe green and blue screens will work much better and there is “less risk”. Make sure that your lighting for the green and blue screens is adequate enough, otherwise Premiere Pro will have a lot of problems keying it out.
Aanarav Sareen
Raine Parrish
October 8, 2005 at 11:42 pmthis is a bit off topic- but i plan to shot the “running footage” seperately- the footage that i’ll actually place outside the windows- i assume i should simply try to shoot normally, at the actual angles i would see if sitting in the car? i.e.car height, aimed out the window, driving at a moderate speed?
thanks gain
rp -
Craig Howard
October 9, 2005 at 9:33 pmYou need to shoot the bg footage exactly how it would be seen from the cameras point of view for the foreground image with the car and the actor. Same lens, lens height and direction but minus the f.g elements of course.
Remember the bg image is unlikely to be totally stable so put some car movement into your f.g shot.
Direction tip: I love the shots when the actor turns his attention away from the road for long, long,long periods of time …and he never crashes.
Craig
Shooter Film Company
Auckland
New Zealand(Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
