Activity Forums Storage & Archiving LTFS with Autoloader
  • LTFS with Autoloader
    Posted by George Boyd on October 28, 2014 at 5:00 pm
    Is anyone familiar with a piece of software with the capability of writing LTFS & communicating w/ an autoloader?
    I am using an HP 1/8 LTO-5 Autoloader – I’m looking for software w/ the ability to change out tapes & format each new tape as it enters the drive. Allowing us to walk away and let the software span the update across 8 tapes w/ out needing to click format on the software and manually move the tapes using the Autoloader.
    Thanks in Advance.
    Tim Jones replied 11 years, 10 months ago 4 Members · 4 Replies
  • Martin Greenwood
    October 28, 2014 at 6:02 pm
    George,
    By coincidence we have just added on the fly formatting to the latest version of our YoYottaID Automation software.
    YoYottaID Automation is OS X software that works with Autoloaders like the HP 1/8 LTO unit you are using.
    YoYottaID can span larger backups across multiple tapes and you can setup a queue from different sources. Then you can use the built in media database to selectively restore files at a later date.
    With the Conform option you can automatically pull back trims of just the shots needed for your edit.
    Please contact me and I’ll get you setup with a demo version.
    Best,
    Martin Greenwood
    CTO
    YoYotta
    martin@yoyotta.com
  • George Boyd
    October 28, 2014 at 10:52 pm
    Thanks Martin.
    Sounds very interesting, we’ll reach out soon and learn more.
  • Neil Sadwelkar
    November 4, 2014 at 3:08 am
    I think BRU-PE also has some feature that supports auto-loaders.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Tim Jones
    November 15, 2014 at 6:47 pm
    EDIT – BRU PE will not solve your original query about LTFS with automation – I was originally responding to Neil’s comment about BRU PE and automation. There are tools out there – such as HP’s StoreOpen tool for libraries – that will allow you to use LTFS with that 1×8.
    However, keep in mind that LTFS volumes created using automation drivers and LTFS tapes created using standalone drive can be incompatible.
    I’ll refer you to this post for specifics:
    https://forums.creativecow.net/readpost/330/1383
    Yes – BRU PE supports autoloader/libraries up to 2 drives and 50 slots. For larger installations (unlimited tape / unlimited slots), BRU Server is the solution.
    Of course, BRU also uses raw tapes, so no pre-formatting is required. Need another tape, just unwrap one and go for it.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.tolisgroup.com
    BRU … because it’s the RESTORE that matters!
