Activity › Forums › Storage & Archiving › LT05 Unarchive Tape Error
  • LT05 Unarchive Tape Error
    Posted by Luke Allen on May 23, 2019 at 2:01 pm
    (Apologize for a double post, but I posted this in the wrong forum, in Storage)
    Howdy folks, long time reader, first time poster! Be gentle!!!
    I have an LT05 tape that is causing me some issues and I was wondering if anyone here has any suggestions on how to fix?
    I’m unarching a tape, which runs fine, untill it gets to a single file, which causes the tape to error and quit. The tape has around 1.3 TB of data, but crashes out after restoring just a few hundred GBs
    Here is the last few lines of my logs
    -rwxrwxrwx tech/domain users 42813440 2015-02-05 22:23:00 mnt/vol1/work/2014_Active/691_REDACTED_IDENTITY/_DELIVERY/MASTER/v002/691_RDI_15_4K/691_RDI_15_4K_00021.dpx
    -rwxrwxrwx tech/domain users 85651205 2015-02-05 22:23:00 mnt/vol1/work/2014_Active/691_REDACTED_IDENTITY/_DELIVERY/MASTER/v002/691_RDI_15_4K/691_RDI_15_4K_00021.exr
    -rwxrwxrwx tech/domain users 42813440 2015-02-05 22:23:03 mnt/vol1/work/2014_Active/691_REDACTED_IDENTITY/_DELIVERY/MASTER/v002/691_RDI_15_4K/691_RDI_15_4K_00022.dpx
    -rwxrwxrwx tech/domain users 85651205 2015-02-05 22:23:02 mnt/vol1/work/2014_Active/691_REDACTED_IDENTITY/_DELIVERY/MASTER/v002/691_RDI_15_4K/691_RDI_15_4K_00022.exr
    dd: reading `/dev/nst0′: Input/output error
    0+75720 records in
    0+75720 records out
    39699087360 bytes (40 GB) copied, 285.675 seconds, 139 MB/s
    tar: Unexpected EOF in archive
    tar: Error is not recoverable: exiting now
    I also have a script I usually use for archiving and unarchiving and it says
    usr/local/archive/tar: /dev/nst0: Cannot read: Input/output error
    /usr/local/archive/tar: Too many errors, quitting
    /usr/local/archive/tar: Error is not recoverable: exiting now
    tar error 2
    I’ve tried options such as
    –exlude – Excluding the issue file type
    –ignore zerod
    -i
    –ignore-command-error
    But everytime they hit the bad file, it stops.
    Is it possible to skip problematic files on LTO? Is there a way of recovering the rest of the tape? Any suggestions would be greatly appreciated.
    Luke Allen replied 7 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
