Activity › Forums › Apple Final Cut Pro Legacy › L&T mts files, 5 minute length limit
  • L&T mts files, 5 minute length limit
    Posted by Marije Nie on March 10, 2011 at 10:21 pm
    After browsing the forum extensively I decided to start yet another post on the mts log and transfer issue.
    When i Log and Transfer only the files shorter than 5 minutes will finish. Longer files will seem to work, but right at the very end it stalls, and i get an unknown error message.
    Does anyone know what is happening here, or is the only solution to convert the files using an external program?
    thnx,
    Marije
    Michael Gissing replied 15 years, 6 months ago 2 Members · 3 Replies
  • Michael Gissing
    March 10, 2011 at 10:51 pm
    The two most likely culprits for file size limitation is FAT32 formatted drives or you have the maximum file size limit parameter in System Preferences set too low. Untick the ‘Limit capture/export file size ‘ option and see if that fixes it.
  • Marije Nie
    March 13, 2011 at 8:56 am
    Hi Michael,
    Thanks for your answer!
    I believe you are right, as my other (smaller) external drive gave no problems. I’ll search for info if I can remove this FAT32 formating…
    Do you know if all big drives have this? (I need at least 1 tb)
    best regards,
    Marije
  • Michael Gissing
    March 13, 2011 at 10:01 pm
    Drive formatting is something to do before any data goes on. Reformatting erases the drive. When you buy a drive, first task is to check how the drive is formatted and reformat if necessary.
    For FCP media, HFS+ non journaled seems to be the recommended around here.
