Activity Forums VEGAS Pro LP mode and Vegas
  • LP mode and Vegas
    Posted by Peter Alessandria on August 4, 2006 at 3:20 pm
    I’m shooting a wedding tomorrow with my DVX 100 and I just found out the ceremony is gonna run 1:15. Instead of switching tapes in the middle I was going to run the camera in LP mode. Will this have any effect when I capture the footage in Vegas 5.0?
    Edward Troxel replied 20 years, 1 month ago 2 Members · 3 Replies
  • Edward Troxel
    August 4, 2006 at 4:21 pm
    LP mode should cause absolutely NO differences anywhere. The data on the tape is exactly the same – just packed tighter together. Consequently, you *may* have to capture tapes from the same camera it was recorded in.
    Generally speaking, it is recommended that you stick with SP speed. I typically do SP mode using 83 minute tapes for longer events.
    Edward Troxel
    JETDV Scripts
  • Peter Alessandria
    August 4, 2006 at 4:36 pm
    Thanks. I didn’t mention I was shooting 24p but assume that doesn’t make a difference.
  • Edward Troxel
    August 4, 2006 at 6:26 pm
    Should make zero difference.
    Edward Troxel
    JETDV Scripts
