Activity Forums Apple Final Cut Pro Legacy Lowering Compression rate
  • Lowering Compression rate
    Posted by Josh Fischel on February 15, 2007 at 11:46 pm
    Hopefully I got it right this time. Sorry i’ve posted so many times.
    I am getting the “Warning-Dropped Frames” window and the only thing, on the list they suggest to change, that I can’t find is how to lower my compression rate. I have plenty of memory and my system is a G5 so it should be plenty fast. If lowering the compression rate doesn’t work, what else? I also already trashed my preferences because my sequence was acting screwy.
    Plus, after I trashed my preferences, I can’t hear the audio. It’s there, I just can’t hear it.
    Josh
    Tom Wolsky replied 19 years, 7 months ago 2 Members · 5 Replies
  • Tom Wolsky
    February 16, 2007 at 12:16 am
    What are the specs of the computer? What are the drives? How full are they? What format are you working in?
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Josh Fischel
    February 16, 2007 at 12:59 am
    Machine Name: Power Mac G5 Quad
    Machine Model: PowerMac11,2
    CPU Type: PowerPC G5 (1.1)
    Number Of CPUs: 4
    CPU Speed: 2.5 GHz
    L2 Cache (per CPU): 1 MB
    Memory: 512 MB
    Bus Speed: 1.25 GHz
    Boot ROM Version: 5.2.7f1
    Serial Number: YM5484GUR6W
    It runs on Mac OSX Tiger
    The Mac HD has 104.62 GB available
    I have two Maxtor One Touch drives
    One has 204.32 GB available
    The other has 70.9 GB available
    And i’m working in DV NTSC
  • Tom Wolsky
    February 16, 2007 at 1:08 pm
    Are you using the drives as FireWire? Are they daisy chained to the rear FW port?
    All the best,
    Tom
  • Josh Fischel
    February 16, 2007 at 8:57 pm
    Yes and yes.
    Josh
  • Tom Wolsky
    February 16, 2007 at 9:06 pm
    So what’s in the sequence? How many tracks or video and audio? What are you doing to them? What RT settings are you using?
    You obviously can’t lower the compression setting. It’s fixed in DV.
    All the best,
    Tom
