Activity Forums Apple Final Cut Pro Legacy Lowering Compression rate
  • Lowering Compression rate
    Posted by Josh Fischel on February 15, 2007 at 9:17 pm
    I am getting the “Warning-Dropped Frames” window and the only thing, on the list they suggest to change, that I can’t find is how to lower my compression rate. I have plenty of memory and my system is a G5 so it should be plenty fast. If lowering the compression rate doesn’t work, what else? I also already trashed my preferences because my sequence was acting screwy.
    Josh
    Josh Fischel replied 19 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
