Activity › Forums › Adobe After Effects › lowering a framerate in a precomp…
  • lowering a framerate in a precomp…
    Posted by Nico Jones on June 8, 2006 at 6:50 pm
    hello everybody,
    I’m doing the old ‘getting posters on a wall to come to life’ effect. I have my subject precomped and then put on top of the poster shot.
    Basically, I want to lower the frame rate of the subjecton the poster to 16 FPS, giving them a jerky kinda look. When I bring down the FPS of the subject composition in the composition settings, the master composition overrides it and puts it back to 25 fps.
    I rendered out the subject at 16 FPS then brought it back in but that caused strange issues. Also; i don’t have time to render out and import a load of stuff…
    So, does anyone know of a way to bring down the frame rate of a precomped layer in AE? Or achieve a similar effect?
    thanks in advance…
    Nico
    Sam Moulton replied 20 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • Mark
    June 8, 2006 at 6:56 pm
    Can’t you time stretch the precomp….
    Mark
  • Nico Jones
    June 8, 2006 at 7:14 pm
    Indeed, but I don’t want a slo-motion effect. I want the same speed, but lower framerate. Like when you lower the framerate of a quicktime for display on the web: same length but jerkier movement and lower framerate.
    like this, in fact:
    https://youtube.com/watch?v=DzqJp332N0k&search=jack%20names%20the%20planets
    Nico
  • Deadittex
    June 8, 2006 at 7:18 pm
    A thought… .
    – why not dupliate the layer then time strech one and leave the other normal.. then cut the one that is slow mow into tiny peices and hand build a slowmo track … or even through in some freze frames
    it’ll look all choopy and you will be in complete control…. ( I don’t know; I had three beers at luch …pay me no mind))
  • Steve Roberts
    June 8, 2006 at 7:22 pm
    Effect>time>posterize time?
  • Nico Jones
    Excellent idea sir! Sadly I don’t quite have time for anything like that at the moment…there has to be a simpler way??
  • Nico Jones
    June 8, 2006 at 7:25 pm
    Well there we have it! I’ve been using AE for about 3 years now and I still don’t know what half of those effects do. One of the perils of being self taught and having no time to read manuals I guess. Actually what am I talking about, it’s just abject laziness…
    thanks steve
  • Tony Kloiber
    June 8, 2006 at 8:42 pm
    In your Precomp Open Comp Settings select the “Advanced” tab check the preserve frame rate when nested or render queue.
    I think that is what you looking for.
    TonyTony
  • Sam Moulton
    June 9, 2006 at 10:18 pm
    I was wondering when maintain frame rate in nested comps would be mentioned. That’s the easiest solution.
