Activity Forums Apple Final Cut Pro Legacy Lowercase Caps / small caps
  • Lowercase Caps / small caps
    Posted by Richard Martz on August 12, 2006 at 5:10 pm
    Recently a client asked us to do a graphic using lowercase caps (sometimes called small caps). We could not find a way to do this in Final Cut (at least by using only one text generator). We did it in Photoshop and had no problems but it woudl have been nice to have been able to do this in Final Cut. Anybody have a solution?
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
    Lots of other Fun Stuff!
    Richard Martz replied 20 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • Peter Wiggins
    August 12, 2006 at 7:07 pm
    Motion does it well -All caps / All caps size
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
  • Richard Martz
    August 13, 2006 at 12:39 am
    I knew that Motion would do it. I just wondered if there was a workaround in Final CUt.
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
  • Thaxter Clavemarlton
    August 13, 2006 at 3:46 am
    Did you try ‘Title 3D”?
  • Chris Poisson
    August 13, 2006 at 2:17 pm
    Yes, in Title 3D you just select the characters you want to be a different size and change the size, it works exactly like Photoshop.
  • Arnie Schlissel
    August 13, 2006 at 7:00 pm
    The easiest way to do this is to use a ‘small caps’ font, where the lower case letters are small caps & the upper case are large caps. You can look for fonts on linotype.com.
    Arnie
    Now in preproduction: Peristroika (Cosmological Congress), a film by Slava Tsukerman
    https://www.arniepix.com
  • Tom Matthies
    August 14, 2006 at 9:50 pm
    LiveType will also do this without any problems. Just select the “small caps” letters and reduce the size. Very fast to do & export.
    Tom
  • Richard Martz
    August 15, 2006 at 9:27 pm
    Thanks for all the suggestions. Next time I need this the information you provided with be invaluable! Have a remarkable day!
    Richard Martz
    MagicMartz Media
    Final Cut Pro HD
    Kona LH
    After Effects
    PhotoShop
    Illustrator
