Activity › Forums › Apple Final Cut Pro Legacy › Lower Thirds Leading
Posted by Stephen Botting on April 17, 2011 at 9:45 pmHi there,
I’m trying to find a way or a plugin that will allow me adjust the distance between the two lines of a lower third.
Any suggestions,
StephenStephen Botting replied 15 years, 4 months ago 3 Members · 6 Replies -
Stephen Botting
April 18, 2011 at 2:04 am[Jeremy Garchow] “Are you using title 3d?”
No I don’t have that plugin.
Stephen -
Jeremy Garchow
April 18, 2011 at 2:19 amComes with FCP. Everyone that has fcp has title 3d. It under “Boris”
Stephen Botting
April 18, 2011 at 2:28 amThere it is, thanks for your help, this will do nicely.
Cheers.
Andreas Kiel
April 18, 2011 at 9:08 amStephen,
If you have to create many Lower Thirds and those might have to be changed during the edit you shouldn’t use Boris. Changes there do cost a lot of time.
Better way is to create (or use) a simple Motion Template.
Another option is to use my free TextUp generator, though it’s more thought for use with subtitles.Andreas
Spherico
https://www.spherico.com/filmtools -
Stephen Botting
April 19, 2011 at 11:19 pm[Andreas Kiel] “If you have to create many Lower Thirds and those might have to be changed during the edit you shouldn’t use Boris. Changes there do cost a lot of time.
Spherico
https://www.spherico.com/filmtools“Hi thanks,
Yeah boris is a little fiddly, this is for a daily post produced news programme, and previously the built in lower thirds worked fine. But we have made some changes and it no longer works for us. I use After Effects, so didn’t think of using Motion. Looks like it will really well, except I cannot get FCP to automatically recognize the template as anamorphic, it is set right in motion, but I have to manually check the anamorphic property each time I use it.I’m using FCP 6.06 and Motion 3.
Stephen
