Activity › Forums › Adobe After Effects Expressions › lower thirds for premiere using sourceRectAtTime
  • lower thirds for premiere using sourceRectAtTime
    Posted by Shahar Bareket on June 14, 2017 at 4:58 pm
    Hi Guys!
    Im trying to create a lower third to be used as a template in premiere and i want it to be as foolproof as possible.
    We work in RTL here (right to left)
    I want the text to slide from the right behind a mask and reveal. thats pretty straight forward with keyframes,
    the problem is, i want it to always hit the same start and end points no matter what the width of the text layer is!
    I can do the math, i just don’t know how to write as an expression to the position..
    I tried it with markers and i guess it works.. (i think it has errors on it though it did worked at some point)
    I just want it to have ease in the timing, and im sure im missing something huge in here and theres a much more elegant way of doing this..
    Any help will be appreciated!!
    s=thisLayer
    r=s.sourceRectAtTime(time-s.inPoint,true);
    n = 0;
    if (marker.numKeys > 0){
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time){
    n--;
    if (n > 0) {t = time - marker.key(n).time;
    if (n == 0){
    value;
    } else {
    if n == 1 {s.property("Position").setValue([1920+r.width,900]);}
    if n == 2 {s.property("Position").setValue([1700-r.width,900]);}
    if n == 3 {s.property("Position").setValue([1700-r.width,900]);}
    if n == 4 {s.property("Position").setValue([1920+r.width,900]);}
    Shahar Bareket replied 9 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
