Activity Forums Adobe After Effects lower-thirds
  • lower-thirds
    Posted by Tielman Dewaele on March 8, 2007 at 11:30 am
    hey,
    Im was wandering what the best way to renderout lower-thirds(textblocks with names and animation on footage), to put on clips in FCP.
    FCP: PAL CCiR6001 16/9 footage.
    AEF: PAL DV1 withscreen 16/9.
    Peace
    Tielman Dewaele replied 19 years, 6 months ago 4 Members · 4 Replies
  • Curious Turtle
    March 8, 2007 at 12:43 pm
    Render out as a Quicktime Animation file, millions of colors+ (so you have the alpha channel).
    You can then put them straight into an FCP timeline, although you may have to render depending on the codec you’re using in FCP.
    HTH
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • David Bogie
    March 8, 2007 at 4:36 pm
    This is just my workflow suggestion:
    you want to stay flexible when editing.
    Create your lower third movies in AE but do not place your text on thim in AE. Bring them into your FCP project as movies and use LiveType, Motion or any of FCP’s fully capable text systems.
    bogiesan
  • Kurt Murphy
    March 8, 2007 at 5:42 pm
    Also, if you used transfer modes in the super (Overlay for the base, normal for the text, etc.)… They will carry over to Final Cut, BUT… you will need to render each layer separately depending upon the Transfter Mode (you can render them WITH the transfer mode in AE as long as it’s over a clear background – it’ll show up as normal in the movie). Bring in each movie and apply a the same Transfer Mode in FInal Cut.
    Hope this helps,
    kurt murphy
  • Tielman Dewaele
    March 9, 2007 at 12:43 pm
    Ok
    Thanks a bunch guys!
    Grt
    Peace
