Activity › Forums › Adobe Premiere Pro › Lower-third video distortion
  • Lower-third video distortion
    Posted by Midwestmonsters on May 26, 2007 at 6:32 am
    Well back again…
    I’m putting together a motorsports DVD and some of the footage supplied to me is on DVD. I captured that footage out of the DVD player, into DV camera via S-video and mono-audio, and Firewire’d into Premiere Pro 2.0
    Footage looks “fine” despite its poor quality in areas, but I’m noticing a big problem when encoding to MPEG-2. The lower third, well, more like the lower 12th, of the video is distorted with a distinct section that appears to be using repeated frames or something.
    Encoding settings are 4:3, MPEG-2, Video only, 720×480, Main Profile, Main Level, Lower Field, 29.97, CBR 5.0, and everything else I’ve never touched.
    any help on this?
    Midwestmonsters replied 19 years, 4 months ago 2 Members · 3 Replies
  • Vince Becquiot
    May 26, 2007 at 3:17 pm
    You are going from a compressed DVD, to analogue, to a compressed 5:1 DV, then again to a CBR 5. That video has been through a lot in just one transfer, and those repeated frames might just have been introduced by the last CBR encode. Have you tried just renaming the vobs to Mpeg2?
    CBR and 5 MB/S don’t go together well if you want to keep some of the original quality. If you have to encode under 8MB/S, then use VBR. Use this calculator to get your exact requirements.
    I would also try a small work area export where the lower third is, to make sure that the encoding rate is the issue here.
    Cheers,
    Vince
  • Midwestmonsters
    May 27, 2007 at 6:24 am
    Thanks for the input Vince. I figured the multiple steps of compression would lead to trouble. I think part of it is just the horrible DVD quality I was given as well. They burned it in an obvious long-play format and its already pixelated severely.
    Anyway, I am able to skip the step of input to the DV camera and back out to the camera. I have a Turtle Beach Video Advantage card for analog input. What, if anything, can that save me compression-wise.
    I’ll mess around with the VBR settings and see what I can get.
    Thanks alot!
  • Midwestmonsters
    May 27, 2007 at 6:29 am
    Another thing I forgot to add in reference to my comment about their poor DVD footage quality, is the fact that I have done the method of capture I mentioned in the first post from some excellent DVD footage and the results were fine.
