Activity Forums Apple Final Cut Pro Legacy Lower third transitions affecting whole screen
  • Lower third transitions affecting whole screen
    Posted by Jim Bell on June 2, 2010 at 8:13 pm
    I’ve got a lower third title that I want to dissolve out so I applied the nonadditive dissolve effect, works great, except, the V1 subject also blurs while the lower third fades.
    Obviously I want to keep the subject in focus throughout… anybody had/solved this?
    JB
    Jim Bell replied 16 years, 3 months ago 2 Members · 2 Replies
  • Michael Gissing
    June 3, 2010 at 12:02 am
    Is this after it is fully rendered? I have never seen a layer blur with a dissolve unless it isn’t rendered.
    You can also apply a keyframed opacity ramp out to fade a title off. Make sure that is also rendered.
  • Jim Bell
    June 4, 2010 at 6:54 pm
    Thanks Michael… at first I thought this was not the cause… I selected everything and did a command R… It said writing vid… Still had problem! BUT, when I output the vid using QT Conversion… (during which the whole timeline goes red suggesting it will be rendered in the process) it came out fine and no blurring at all. Thanks. Am I not rendering in the program correctly? Is there a better command? Or is this something you just live with till you output?
    10.6.1 Macbook Pro 17″ w/express 34, G-Tech 2 TB GRaid, TC Electronic Impact Twin FW audio interface
    Hindsight is always 1080p – Thanks to Zane Barker, this made me smile…you too?
